Crankcase drawings
Does anyone know of a source of crankcase drawings? Any year will do but earlier would be better.
Thanks
Charles
What do you need to know Charles?
(14-12-2019, 03:29 PM)Ruairidh Dunford Wrote: What do you need to know Charles?
Specifically the position of the crank and cam centre lines, in relation to the rest of the crankcase (which really means using the block studs positions as reference)
C
I has responded to your WhatsApp message.
This is the nearest thing I'm aware of Charles.
I fear you're on your own if trying to establish dimensions/ clearances.
Of course dimensioned crankshaft drawings are also available as a reference.
(14-12-2019, 04:16 PM)Chris KC Wrote: This is the nearest thing I'm aware of Charles.
Thanks Chris.
I have that one and as you say, I'm probably going to have to do it myself
Charles
