Bearing serial numbers
Does anyone have a record of the serial numbers on the back and front wheel bearings ,  and all the gearbox bearings for a 1934 ,  4 speed  Austin 7 RP  please ?.
Front Hub Inner: SKF RLS10 (sealed 2RS ), RHP LJ 1 1/4
Front Hub Outer: SKF RLS6  (sealed 2RS), RHP LJ 3/4
Rear Wheel Hub:  SKF RLS10 (sealed 2RS ), RHP LJ 1 1/4
(RHP is Ransome Hoffman Pollard using the same numbering as R&M)
Many thanks Tony …. sorry for the late reply !.
