I have a question for the experienced engine builders:
When balancing connecting rods, where is the best place to remove material from on the big end and the wrist pin end to lighten them to match the weight of the lightest rod ? You can appreciate that I don't wish to weaken them in any way.
Thanks,
Stephen
HI Steve,
What type of rod, Standard Clamp bolt fully floating After market ?
Also min and max weight for both Ends
Colin
NZ
Hi Steve,
There's quite a bit of material around the big ends but not much at the little ends. Depending how close they are I would suggest you balance to the second lightest rod and try to add to the lightest by trying different gudgeon pins - there is variance of a few grams amongst different batches depending on how big the hole is made. Fine adjustments come from a washer under the big end nuts and varying the clamp bolt length. It is possible to get within a few grams on this but you need lots of patience and keep rechecking your measurements for consistency.
Hope of use, Dave
Also any place where a previous owner has made between one and four hacksaw cuts to indicate rod number (wince). Smoothing these out will remove the stress raiser; though you might do better to find another set of rods.
Steve - apologies if I sound like trying to teach my Grandmother to suck eggs, but have you crack tested the slots at the little ends? A known point of failure and absolutely needs to be checked if you have not yet done so...
hth!
HI STEVE,
If these are for a standard or mild performance upgrade, I would just check for cracks also the condition of thread for clamp bolt,
lightly grind out any forging marks ie a long length of rod and on the cap.
Replace the cap bolts and use (HT) Nylocs. Reason they will have stretched and the Nylocs because they can be TORQUED to the set ftlbs
and left were as castellated nuts might have to be over tightend to line up with hole in bolt.
Lastly if the rods are Relatively close in weight I would not bother to get them spot on
Hope that Helps
Colin
NZ
