windscreen brass
Hi I have new old stock windscreen section I now no longer make them so old stock to go.
each length is 3.6 metres long by 20mm x 15mm this sells for approx. £50 a metre that
equals £180.
I want £75 this is new old stock and is cold bendable.
.jpg   709 section.jpg (Size: 11.28 KB / Downloads: 276) Is this the 709 section that is sold by vintage Supplies?
That is the same section that you have posted, I did upload some photos but will check.
Thanks
I'm in Stockport south Manchester, where are you? Do I collect or is it by a carrier?
hi I live near Southport
being 3.6 meters long and is quite heavy, your welcome to collect.
1 length will do a complete ac cobra windscreen for example.
Thanks
OK so it looks like I'll collect when are you in? As of a matter of interest how old is this?
anytime you want I will be available if you give a day and time I will send address.
Thanks
sorry about the delay again but its that time of the year things need to be done outside.
Sorry for the delay, I'm pretty well booked up, I may be able to pick it up on Monday.
that is ok for Monday I will be around.
Thanks
Sorry Monday is off, I've sent you a PM.
