Thinking of replacing my number plates with a new set of correct vintage.(1927)
Can any one recommend a supplier and period style I should use.
Many thanks
Paul
Classic Transfers make some nice number plate stencils at reasonable prices. In 1927 they were probably painted freehand but that's harder than it sounds.
Car type: 1932 4-seat Tourer, 1925 Pram Hood Chummy
Originally fitted were pressed steel beaded edge rectangular plates. Those supplied new by Complete Automobilist (Ref NPA-ob - steel back plate - oblong) are almost indistinguishable. Paint the registration number on yourself, or get a local signwriter to do it, as was the norm back in 1927. Previous threads discuss lettering styles.
One way to do it is to spray paint the number plate area white. When the paint is dry and hard stick on self adhesive letters and numbers to make your registration plate. Then again spray the area again but this time in black. When dry carefully peel off the stick on letters and numbers to reveal a white on black number plate.
John Mason.
Hi Paul
The Cornwall A7 web site has several articles on number plates. I used their method of chalk stencilling on the RK with excellent results. I would also recommend a cream rather than white paint for the digits. White tends to look too white!
Car type: A7
Classic Transfers as well as stencils they also do self adhesive letters correctly spaced ready to stick on a black back ground they will also space them out for a square number plate to go on the back of an ulster. Quick and easy to use with a period font.
