Just pondering before I send the parts off.
Does anyone have qualified opinions on the value of dynamic balancing the full bottom end (crank, flywheel, rods, pistons) vs just the crank & flywheel?
It strikes me that crank whip must impact the value of balancing but how much?
I'm assuming that pistons and rods are statically balanced.
Thanks
Charles
Charles,
I dynamically balance all my cranks and flywheels together.
I try to get the rods and pistons as close to each other in weight as possible, using a digital scale.
This makes a tremendous difference in smooth running, highly recommended.
I have run both fully balanced and unbalanced engines, I agree with Ruairidh it makes a marked difference and must reduce the stress on components particularly if you intend to rev the engine.
15-11-2017, 09:29 PM
(This post was last modified: 15-11-2017, 09:31 PM by Alan.)
I wouldn't build an engine without dynamically balancing the crank and flywheel assembly together as a unit. Static balancing is not good enough. The rods and pistons I just make sure are matched for weight.
Would it be worth adding the Cluch cover( on an early coil engine) as well?
It’s a chunky item.
Also is it worth taking half an inch off the rim of the flywheel first?
BillG
Sorry - added my two penne'th on the other thread before I saw this...
16-11-2017, 01:31 PM
(This post was last modified: 16-11-2017, 01:36 PM by Hugh Barnes.)
That is exactly how I did the Riley engine... Even to the obsessive point of marking each bolt head and threaded hole so the original blts went back in the same place when I finally assembled the clutch....
As an aside, the Riley flywheel and clutch weighed a ton, so I consulted various knowledgable people about lightening. The comments I got back were that a lightened flywheel in the Riley engine moved the harmonic frequency and the point of maximum effect would be moved right into the middle of the touring speed rpm. The only cranks I have heard of breaking in that engine were those that had been lightened.. Specific comments on the Riley engine and only added as an aside for interest..
