23-09-2019, 08:55 PM
(This post was last modified: 23-09-2019, 08:56 PM by Ian Williams.)
I found hotter projected nose plugs helped on a car which burnt a bit of oil.
However I would normally suggest Alans original advice of fitting B5HS is the way to go.
Yes,, long nose is what he meant, and L87Y was the plug.
On the same theme I do not recall mention of long reach plugs until the 1960s. The huge majority of plugs were not. There must be some reason why not almost universal earlier. Perhaps the large number of s.v engines brought risk of valve contact with many so the type was generally avoided.
From daily observation with my Seven I reckon plug gap effectively alters the spark advance The very recessed plug would certainly alter combustion.
These were certainly still commonplace in the 1990s when I was using a Seven as my only transport - very effective they were too.
They might help help oil fouling but most certainly don't help flame travel, I guess that is of little consequence if your engine is so bad that you need them.
When I put my car back on the road in 1999 without having removed the head - it had been laid-up for 20 years - the local PWA7C club president Vic Wilde lent me a set of these - he called them plug extenders. This allowed the engine to run well enough for the first few hundred miles without oiling up the plugs. They have not been needed since.
Colin
Many thanks to all for the expected detective work. Not sure that I believe everything, by that I don't mean the comments but mean the offer of "free next day delivery" from Memphis to Abergavenny, neither from Tennessee nor just up the Nile. I share the sense of wonder that a poor little 6 volt spark could find its way down to the combustion chamber but as suggested, any engine that needs them is unlikely to be warming up the rear tyres on starts. If a certain distinguished person was still using them in the 90s maybe Ian Dunford still has a box in stock hidden away somewhere. Let's see if any can be spotted in the paddock at Prescott on Saturday, highly unlikely I think!
