I'm fitting indicators to my AAK. Not an easy task when taking over where the previous owner left off long ago, but I'm getting there. My question is, were do other members run their wires to the rear indicators?
Pete
1935 AAK Tourer
I ran mine along the bottom of the body and along the rear chassis, following the original wiring loom route.
Yes, I believe this is the best route as David did. I used black sheath covered 3 core flex running along the existing loom fixed with small black cable ties so it's hardly noticeable either underside or under the bonnet! The 3 core gives a lead for each side plus earth so I can identify what colour is for which side.
