Electronic Distributor
#21
FET = Field Effect Transistor, power ones are referred to as HEX FETS name due to construction in the silicone. They are a voltage controlled device like a Thermioniic valve. You raise the gate voltage to a certain threshold and the Drain Source junction begins to conduct.
