Hi all
putting the engine back together and whilst putting new cylinder head studs in.....one stud snapped flush with the block (stud between no 2 and 3 cylinder). I was trying to put car back together for Cotswold trial. Would it be a wise move to run the car minus one stud. Or is this considered to risky?
thanks for nay help
ollie cox
Will be more or less end of head gasket, and some risk of internal water leak, perhaps even hydraulic lock. The uneven pressures stress the block and, as with excessive tension, tend to promote cracks. It is largely to avoid this rather than permanent distortion that heads are tightened progressively.
Ollie,
I'm with Charles on this one, you don't really have an option.
J
Hi Ollie,
If it was my only way to get home I'd run it, not if I had a choice. Especially not with any kind of alloy head as you are asking for it to warp.
It troubles me a little that you managed to shear a new stud putting it into the block... I normally just nip them up. They ought to be comfortably able to cope with 20lbft. Was it perhaps a bit too much enthusiasm?
Chris
I guess the old one snapped taking it out.
Hard luck and frustrating dilemma but no brainer with an Alloy head. On a slightly tangential tack what are regarded as 'good quality drill bits' ? I don't seem to have had any lasting that long but that's possibly due to my lack of skill.
11-11-2017, 07:20 PM
[attachment=1376]
Woodrow Manual gives a very useful tool for drilling out broken head studs, pilot hole first then hole for tapping a new thread, the guides help take out the chance of getting it misaligned. Good luck with this!
