Car type: RP 1934
Hello Smiley!
Thank you very much for your post and the information. Bit by bit I am getting closer to at least knowing what I have to do, if I do it... Do you have a photo of the hole? I would add it to the others and describe the matter in German.
Thank you very much
Frank
Car type: RP 1934
Hello Adrian,
thank you for your reply and the link. I have already checked the internet for suitable leathers, but could not find any suitable seals. Obviously it makes a huge difference to use metric or imperial sizes. I am absolutely not used to UK measurements... really time-consuming to figure it out. I know that the size of the brass tube is 38 mm on the outside. The seals CP630 (1 3/8") would be 35 mm. Theoretically 3 mm are missing. When you inserted the seals, were they tight or loose or did the oil or grease expand the seals? I will certainly contact your supplier, so thank you for the information... would have never found it. Once again a huge step ahead.
Thank you and regards
Frank
Car type: Austin Seven RP 1932
Hi Frank, I have sent you an email with the photo as promised. Let me know if you receive it ok. Cheers
Smiley.
Car type: 27 Chummy
Hello Frank
Just checked again and definitely CP630's.
I too was a bit unsure but went slightly smaller as they would expand with the vacuum. The size ended up spot on neither tight nor loose. They are working perfectly for me.
Soaked mine in engine oil. Mine also had a felt pad inside the leather cup which holds extra oil.
Good luck.
Adrian.
Car type: RP 1934
Hello Adrian,
after your post I immediately had a look at the homepage and - after a nice chat with the shop owner - I ordered them. Cannot wait to receive them and I will certainly report about my experiences and the results. So thank you very much again for your brilliant tip. I had absolutely now idea which size would fit and as I said before... metric vs. imperial.... no chance.
Regards
Frank
Car type: Ruby sports trial special .
Not on a 7 but on a Ford e93a I fit
A small 12v vacuum pump that worked
Well on 6v and used that to run wiper put it
Out of view and use hidden switch to turn on
Ps found pump on feabay
