06-08-2019, 10:25 AM
As said rear hub size went larger to take larger bearings and longer half shaft taper and diameter. After a while someone realised it would make life easier if all hubs were same so the front inner (really called the seal or felt carrier) was made larger so the same front and back so interchangeable. They didn't think that 80 years later this may cause a bit of confusion
Dennis
![Big Grin Big Grin](https://www.austinsevenfriends.co.uk/forum/images/smilies/biggrin.png)
Dennis
