Surplus Spares available
For Sale
Starting handles,good ferrules.       4 blade fan and al.dynamo housing.
BTH magneto was working fine but now has a gear wheel with several broken teeth otherwise excellent.
1930 ish scuttle petrol tank.
3speed gearbox for uncoupled braked car. Selection of cylinder heads 18mm
P.s. Oil pressure gauges for Vintage A7's and also Rubies. David Harcourt type.
Email Les Gammon or 07786506600
I've left you a message on your phone.
I would be interested in a decent 14mm "Ruby" type head. I am in Leics,where are you? What price, postage etc? Regards RW
An RK is looking for a screw on petrol cap...........
and I could use a decent useable petrol tap (with reserve pipe still there!)
(27-06-2019, 12:05 PM)richard wyatt Wrote: I would be interested in a decent 14mm "Ruby" type head. I am in Leics,where are you? What price, postage etc? Regards RW
Dear Richard
I still have one Ruby head. 1A 911 it is in good condition but it has had some metal ground off thus riding the compression ratio. You are welcome to see it
I live in Redditch Worcs. 07786506600 The prices is £50.
Regards
Les G
Dear David
The tank I am selling has the correct brass screw cap and is otherwise in good order apart from a well executed small patch on the underside. No dings and dents. It is £80. I do not have the correct petrol tap that you seek bu t I could help out with the brass on/reserve plungers. You are welcome to ring 07786506600 I am in Redditch,Worcs
Regards
Les G
Thanks Les
I will give you a call over the w/e
David
Okeydokey x
Ruby head- Thanks but no thanks RW
Thanks to Les and your wife for your hospitality today.
