Car type: Arrow Competition 75
Indeed what is the collected wisdom on testing and setting up the dynamo, off the car. We have rebuilt ours but dont get get 6 volts when spinning it up in the lathe. Looking at the gearing the generator spins at greater than engine speed, should 2000 RPM give full volts at no load? What speed shoul I use to set the third brush.
Car type: 1932 RN saloon
Dave,
I set up a rig with electric drill and piece of strong hose connected to the shaft of the dynamo after first removing the drive gear. I tried 5 dynamos which I had rebuilt years previously. I was initially very disappointed with the voltage readings I was getting. These varied from about 1v to 4v if I remember correctly. In disgust I put the rig and dynamos back in the cupboard and got on with other things for a few months. I then tried them all again later and found that if I let the drill rig run for a few minutes there was suddenly a big increase in torque which twisted and destroyed the hose drive and also showed that the voltage generated was certainly over 6v in all 5 dynamos once I used a more substantial hose. I will have to refer to some notes I made at the time and re-post later.
Cheers,
Dave.
Car type: 27 Chummy
For the dynamo to produce any output there must be some residual magnetism in the field coil cores. Some times it takes a while for this magnetism to generate enough power to properly energise the field coils. Also because the starting voltage is very low any oil or contamination on the commutator will prevent the field getting energised.
Adrian.
Dave,
Here are the results of dynamo voltages. First test followed by second test:-
1929 chummy 4 field coil dynamo 0.24v and 12v. C35A with C35M brush gear 0.1v and 8v.
C35M 0.9v and 12v. C35A 0.1v and 8v. C35M 1v and 7.9v. C35M 0.4v and 8v.
As Adrian says these dynamos needed a good few mins running before the field coils would function.
They had been in the cupboard for many years.
All 6 dynamos work as motors.
Thanks Dave for the detailed info it now gives me hope that with a bit more patience and lengthy high speed running I might get the results I had hoped that I'd see.
To bench test a dynamo I use a piece of 1/2" square bar with one end turned to 1/2" diameter to fit my electric drill and the appropriate socket to fit the drive gear nut on the other end. The dynamo is securely clamped in a vice with and you need to hold the drill very firmly otherwise it could end up on the floor. You may need a jubilee clip on the drive shaft to stop the socket migrating towards the drill and if it's a reversible drill make sure it drives the dynamo clockwise looking on the drive gear end. At about 2500 rpm I find a standard dynamo in good condition generates between 15 and 20 volts depending on how much grunt the drill has.
