1932 Saloon Restoration
#41
OK WiandeV, so what does yours have, is it an RN or RP?
RN, After some research that is what I have.
A RN with rear tank and 4 speed box.
    If it has the original transmission tunnel you will find the body number stamped in 1/2" high digits behind the handbrake cover, the cover usually covers the number. See photo below
Dave - I presume that also shows the RN letter prefix in the row above too?
Thats actually my RP but I presume the RNs were similarly stamped.
Thanks I will have a looksy.
Thanks Reckless, it's a good photo for this purpose. Yes WiandeV above (or in front) of the numbers is the body designation letters RN in your case.
Did you find the number?
