Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
04-03-2019, 10:53 AM
(This post was last modified: 04-03-2019, 12:15 PM by Derek Sheldon.)
Non bumper models had a removable starting handle. The mounting brackets on my Opal are set back far enough to use the handle in front of the plate.
04-03-2019, 12:59 PM
(This post was last modified: 04-03-2019, 01:05 PM by Derek Sheldon.)
I have an Opal / 2-seater type long nosepiece with square ended shaft which I am prepared to sell to someone who has a use for it. I do not have the handle to go with it, but this should be fairly easy to make; come to that I have a standard handle spare (without ferrule) which could be modified.
Robert Leigh
The cranked handle (fixed and removable) is key to it working if the number plate is fitted in the correct place for a bumperless car.
Presumably bending a handle into a cranked shape is possible, or are the very brittle Iron?
The one I posted above is the only one like it that I have seen. It looked to have been done very well, I am tempted to say factory but have never seen another...
Many years ago a friend had an Opal with a detachable starting handle, and another Seven owner not used to the detachable feature swung the engine, the handle detached and smashed an original headlamp glass.
In the late 60s trying to start my Opal after a flat battery due to the parking lights having to be left on, I managed to hit myself on the cheek bone with the squared end of the starting handle, I've still got the scar. I've not done it since.
