  • 5 Vote(s) - 2.6 Average
All Alloy Cup progress
After many hours of measuring and making about 30 armoured cables, soldering the end
fittings , and heat shrinking the ends to stop the alloy windings unwinding,
I finally get to fit them and their junction boxes into
the engine compartment.
The pair of 6 way Lucas junction boxes on the inside of the flitch plates
provide power to the dipping headlamps, sidelamps and front flashers,
Plus earth wires as I’m using 6v LED’s all round
When fully wired up I’ll test each circuit out before dropping
The engine and gearbox in. Next nice job is to fit most of the instruments.
There’s a multi core umbilical from the metal bulkhead back to the dash control panel, plus another umbilical( trailer cable) back to the rear lamp clusters.
Any suggestions for getting speedometers overhauled?
Regards
Bill G
.jpeg   D9127D19-85F5-4B65-B42D-21CB8BA700C6.jpeg (Size: 75.33 KB / Downloads: 245)
.jpeg   C0660BA2-5764-4151-B452-461B7B26466A.jpeg (Size: 75.54 KB / Downloads: 245)
Nice, neat tidy wiring makes a huge difference on a car. It looks very clean. We had a DRO sensor die on a machine at work once so they replaced it and threw away the old one. I nabbed it just to get the armoured metal sleeve off the cable from it.
Simon
Very nice Bill.
.jpeg   D3123E51-C35B-4405-BDC5-467C8E0BE20E.jpeg (Size: 94.6 KB / Downloads: 176)
.jpeg   F73FFB36-731A-4229-BB60-FBEE3F8C054B.jpeg (Size: 96.59 KB / Downloads: 174)
Wings came back from the welder looking much better and
He even did most of the dressing of the welds so just a little work with a
palm sander should sort it out, before finishing with the Scotchbrite and
Nyalic. They are all pre-drilled so should just bolt on easily when the lacquering is finished.
Thinking I may need some stone protection under the front wings? Anyone with alloy wings care to comment?
Regards
Bill G
Aka AllAlloyCup
(01-03-2019, 05:21 PM)AllAlloyCup Wrote: ... Thinking I may need some stone protection under the front wings? Anyone with alloy wings care to comment?
Regards
Bill G
Aka AllAlloyCup
Bill, that was my immediate thought when you said you were making the wings in alloy. I reckon you need a coat ofrubberised paint at least to protect from flying stones.
.jpeg   94450FFF-BF07-47EE-A1BB-359F6B82F5EB.jpeg (Size: 24.66 KB / Downloads: 137)
£40 buys enough to do 4 wings and some
Parts of the cockpit.
I’ll probably go for this type of material
Regards
Bill G
Technical advantages:
  •     Self adhesive 2mm butyl based rubber visco elastic polymer active layer
  •     Aluminium constraining layer for maximum noise reduction improves performance
  •     Highly efficient vibration damper
  •     Superior performance to comparable products
  •     Contains 30% more active material than the Dynamic sounding brand leader
  •     Highly efficient performance requires less product
  •     More economical in use compared to competitors
Product features:
  •     Soft and easy to use
  •     No nasty smell unlike inferior bitumen products
  •     Military grade adhesive stays stuck even in extreme temperatures
  •     Non flammable
  •     Professional butyl based construction
My son used that sound deadening material on his E30. Worked well, but weighed a ton.
Jamie.
Speedograph Richfield in Nottingham have done speedos for me and I've found them helpful and efficient.
Hi Jamie
The full pack ( 30 sheets) weighs 3kg if I used it all. I think the 4 wings
Together weigh less than 6kg! At 2mm thick it’s thicker
than the wings which I think are 1.6mm!
If I put it on with a heat gun onto clean bare aluminium
it’s going to stick on well.
My car is already ultra light and a couple of extra kilos won’t
Make any difference I suspect? I could do with losing a few kg myself
and that might make some marginally more space in the cockpit for a passenger?
Regards
Bill G
Hi Duncan
Thanks for the lead, I’ll check out how much they charge
For an overhaul of one of these governor type speedo heads
Regards
Bill
speedograph richfield wouldn't do any chroming for me. So bear that in mind. Otherwise I gather their work is excellent
Users browsing this thread: 23 Guest(s)
