(20-02-2019, 08:19 PM)Greig Smith Wrote: If anyone wants more details on how to make these conversions, let me know and I'll post pictures, alternately if you are very patient we can assemble & send you a set.
Aye
Greig
(19-02-2019, 10:55 PM)Jays Wrote: Out of interest is the Bowdenex system still available?
Greig,
I should be very interested if you are happy to post any details of your conversions. I am planning to use Bowden cables with TLS brakes and the Jack French (?) shortened cross shaft arrangement, so any pictures or drawings would be appreciated.
8 Location: Port Elizabeth, Sunny South Africa
27-02-2019, 07:13 PM (This post was last modified: 27-02-2019, 07:25 PM by Denis Sweeney.)
Further to my earlier posts and discussions with Reckless Rat I have attached here a document which shows the brake arrangement on my July 36 registered early Ruby.
Hopefully this time with the attachments...…...
Denis S
Denis S
Denis S
Undo the handbrake adjustment completely - it will allow the cross shaft arms to come all the way back. After this you can bring up the fronts, then rears.
Be warned that mixing Austin and Girling in a coupled system does not always work perfectly.
All the system I have is what came with the vehicle when it was purchased 35 years ago, I have always assumed this was as original. I did mention in an earlier post that back when I first had the car I did have long dialogue with Jack French and he was of the opinion that it was probably how it left the factory but I have no way of verifying this.
Many thanks for the info, I will get back under her again and have another go, will let you know how I get on, if that is ok.
Thanks again
Denis S
I am not sure if it applies to your car or not, but on my slightly earlier car I have been helped a lot to understand the condition and effectiveness of the brakes by uncoupling them.
The handbrake works the fronts, the footbrake works the rears, you use both when you really need to stop.
The uncoupling is done by removing a cotter pin on the cross shaft, near the handbrake.
When I am happy that everything is working as it should and balanced side to side, I will put the cotter back in.
Having driven an uncoupled (1928) car for many years I am used to this arrangement, and have been known to grab fresh air from under the dashboard whilst trying to stop a modern car in a hurry!
28-02-2019, 06:49 PM (This post was last modified: 28-02-2019, 06:54 PM by Denis Sweeney.)
Overall picture of the cross tube, I will follow this up with a picture of the outer lever to the back brakes
Denis
Nearside outer lever, both taken yesterday with the cross tube in the same position as the photo taken today.
Denis S
