Took my MG TD to auction at Historic’s Ascot and then onto Dartfird to pick up my Austin 7 which has recently arrived from America
[img]blob:http://www.austinsevenfriends.co.uk/8880a520-4e15-4e49-8574-5e90abb58797[/img][img]blob:http://www.austinsevenfriends.co.uk/8cb0d24b-6853-4180-9ca1-ba91df11324d[/img]
Took the dog for a run round Bala Lake to put some more miles on the Seven after fitting a new rear main bearing (see thread 'Rear Main Bearing'). A quiet meander along the south side of the lake through Llangower through to Llanuwchllyn and then a fast run (40 to 45 mph so fast for a box saloon) up the A 494 back to Bala. Super fun! The engine makes all the right noises now - Industrial sewing machine with a hint of tin trays falling down stone steps. Will have to sort the back axle out sometime. It growls worse than the dog!
Funny that you RP and RL are both Welsh registered cars. TH is Carmarthenshire and EJ is Cardiganshire.
Hedd. That external spring is a genius idea. Simple but effective short term fix.
