A7 HAND CONTROL TUBES
I recently acquired a pair of control tubes, as the inner one on the column from The Thing from the Cesspit (1933 RP) is broken.
Having cleaned them up, I then realised that replacements are both shorter - outer tube 29 3/4" against 32 3/4" - and a smaller diameter - 1/2" against 9/16" - than the 1933 item.
Can anyone confirm whether the replacements are from an earlier A7? If they are, I'd be happy to swap or p/x them for a later set.
My next problem is to extract the tube from the steering box - it feels like it's been welded in!
off a chummy with a dished wheel Martin.
If you struggle to get them martin,
I have some thin wall tubing here, I often have to swap them over for Ulster builders.
Tony.
(20-01-2019, 08:28 PM)Martin Prior Wrote: I recently acquired a pair of control tubes, as the inner one on the column from The Thing from the Cesspit (1933 RP) is broken.
Martin,
The Control Bracket (fixed) tube appears to extend through the brass socket ?
Tony P.
