Ruby running great again, I think I was being a bit to technical looking for problems that didn't exist, with the carb off I give a squirt of easy start into the manifold she fired up straight away for a few seconds, so I put the carb back on gave it another squirt of easy start, she fired up and then kept running on the petrol. I don't like the stuff (easy start) and I have seen so many engines ruined by it, but it does what it says on the tin and can sort out a problem.
Thanks for all replies
Graham
In Australia the same product is called "Start you Bastard!"
Probably was a combination of things - is your fuel reasonably fresh?
when I struggle getting a seven to fire when everyrhing else suggests it should. I often put a drop of fresh petrol down each bore.
ive got a brass plug cylinder head on my chummy
For Ruby owners like myself you can just remove one plug and put a small amount of neat petrol down the plug hole. Reinsert the plug and away she goes. Sometimes coughs a little until the other three fire up but soon runs sweetly.
John Mason.
Short squirt of Brake Cleaner into the carb air intake! Make sure it's a short squirt though.
