A short length of tube of a similar(ish) OD to the bit of the bearing inner that's visible is what I use. Insert tube from rear of bearing carrier, light tap on end of tube, bearing out. They aren't held in place particularly tightly.
Short lengths of tube of an assortment of diameters are useful for all sorts of things when working on Sevens.
I would put blocks of wood (or similar) under the face to take the blow rather than standing it on the studs. If the bearing is being replaced no need to worry about hitting it.
Maybe it's just the photo Peter but did that have any gasket / sealant between the two hub halves when it came apart?
Just a reminder for bearings:- the moving race is usually an easy push fit while the static race is tighter fit......in the case of the hub - outer is moving so easy push fit in hub and felt carrier; whilst inner is static so a harder fit on the axle (also in this case is held by a locking nut.
If you use a bearing with seals either side, the seals can be prised off to clean out dried up/dirty grease and re-grease, they can then be pushed back in place.
Dennis
Whilst I have your kind help on these pics, in the first pic the sharp eyed amongst you will notice that the brake backplate has rusted through slightly. This is the only point of thinning and rust, so can I ask that whilst I am aware replacement backplates are available, would you think a repair with Quck Steel apoxy after rust prevention etc would be an fairly successful, intermediate solution?
16-01-2019, 07:19 PM
(This post was last modified: 16-01-2019, 07:37 PM by Bob Culver.)
Assuming it has not just been bunged up with Loctite you are fortunate the bearing is still a neat fit. It is important the felt retaining washer is retained and any gasket not so thick that the bearing is not clamped. Covered extensively in earlier posts. Provided the bearing is not rough, clearance is of little consequence; a new close tolerance bearing with no tilt is inappropriate.
Previous posts have also established that part fill of diff is adequate and necessary to limit leakage.
The perforated backplate seems an ideal use for filler. There is sure to be some other task warranting effort rather than re rivetting back plate. Signs that the drum has been rubbing.
The axle taper is vital and must be restored very tight. Perhaps leave out the split pin at least initially so can be kept tight.
