Sounds like an ignition problem. Take one of the plugs out touch it to earth and see if it's sparking when you turn the engine over with the ignition on. Don't hold the plug lead while you do it!
15-01-2019, 03:56 PM
(This post was last modified: 15-01-2019, 03:58 PM by Chris KC.)
Graham, what have you changed since it last ran OK?
If you removed the carb to strip it, are you quite sure the new joint to manifold is airtight? A small air leak here will kill starting.
p.s. 1/16" plug gap? I would have used 20 thou; but I doubt this is your problem.
Perhaps if you stop calling her 'it'?
How old is the petrol Graham? If in doubt empty the carb bowl and refill with fresh petrol.
Try starting it with the handle not the starter - the starter will reduce the spark if the voltage is at all reduced.
Peter.
15-01-2019, 10:24 PM
(This post was last modified: 15-01-2019, 10:26 PM by John Mason.)
How long is it since the engine last started up. If it's 6 to 8 weeks it could be stale petrol. Remove the float chamber and discard the petrol in it. Fill with new fresh petrol (petrol that is new or kept in an airtight container) then try the starter again with and without choke. If it runs you have proved its the old petrol. If it does start don't discard the old petrol in the tank it will probably run on the old once the engine is hot.
You beat me to it Peter we must have both bean typing it in at the same time
John Mason.
The inlet manifold and tops of pistons might be awash with far too much petrol. 'Flooded'.
If there is a spark at the plugs, and plugs are wet with petrol, then flooded sounds most likely.
