I am going to run an oil filter so I should be ok with the classic I think (plus that's all Repco had). But not suitable for gearbox? Too heavy as Chris suggests?
It seems like oils are like domestic LED bulbs, if SAE 20 acts like SAE 30 and a 9watt LED is like an old 60watt bulb. I wonder what the viscosity of our oils are like just before we do an oil change, thinner or thicker. In my case definitely thinner as I rarely top up the engine oil, so I suspect that it is thinned out by petrol as there is little evidence of condensation around the oil filler.
Without labouring the detail too much, multigrade oils achieve the 2nd figure by means of polymers which have a tendency to break down as the oil ages. Thus a 20W50 will ultimately behave something like an SAE 40 when hot but is probably a bit on the thick side when fresh. A 20W60 (must admit I've never heard of one till now) will be that much thicker. A multigrade is definitely a better bet than a straight grade as it reduces the amount by which the oil thickens as it cools, thus improves oil flow on a cold engine, which is where all the damage occurs.
Car type: 1932 RN saloon
11-01-2019, 10:31 AM
(This post was last modified: 11-01-2019, 10:32 AM by Dave Wortley.)
Been in garage since 6.15am relining chummy rear brakes. Put the wheels back and noticed one has 3 broken spokes. B*gger!
After my gearbox imploded in July on the way to the Scottish Austin Seven Club Rally at Guildtown, i have finally got the replacement gearbox fitted, so thats us back on the road!
