19-12-2018, 10:27 PM
Finally completed the Seven Special 1927 6v rewire, amazingly everything works, well almost.
After standing for a couple of months she refuses to start.
Turns over well but will not run, however when I wired the new magneto fly lead and tightened the securing nut the cover rotated slightly. I'm no magneto expert but I'm assuming this has either advanced or retarded the timing? Nothing else was touched on the magneto and it was not removed, does anybody suspect this as my problem?
I did rotate the cover slightly and She would idle (very low revs) but as soon as I engaged the throttle she stalled.
Manufacturer B T H?
Many thanks
Manufacturer B T H?
Many thanks
