Car type:
Chris - sorry... I'd made an assumption.
But I see its only Jan-June 1931 in the final ledger so must be partial. Sorry to have got your hopes up. How irritating.
Car type: 1934 Austin 7 AVH Van (in bits & incomplete!), 1936 Morris 8 Series I Tourer
03-12-2018, 06:17 PM
(This post was last modified: 03-12-2018, 06:27 PM by Jeff Taylor.)
Chris,
If it were possible to find out from the DVLA what its original registration was prior to them issuing it with its current age related plate (assuming of course that they know), then there may be County Licencing Authority record cards in existence which may confirm if it was originally a van, original owner etc. Not all County Licencing Records do exist, but you may be lucky.
Try reminding them that the disclosure of a previous registration number is not covered by the Data Protection Act which applies to the disclosure of personal data only!
Mike. The info above states first registered in 2015. e.g in their terms they have no evidence of previous registration therefore to all intents and purposes it never had one.
Its got an age related plate (which is obvious by visual inspection). So any claim it may have had in the past never amounted to anything so nothing will be 'on file'.
Chris. You have your work cut out going that route. Checking each counties surviving registration docs in the hope your chassis number is actually recorded. My view is you have a better chance of a martian landing in your garden.
Its a pity because a 3 + 3 age related is inappropriate for a 1931 car. Particularly as the X and an S make it stand out as age related.
Interestingly Ive been looking at early BF registrations in Dorsetshire. When the Bloody Fool brigade moaned enough the cars were all simply re issued the alternative FX but keeping the same numbers
Car type:
then, Staffs got lumbered with BF! No one complained. I guess its a different socio-economic mix.
03-12-2018, 10:12 PM
(This post was last modified: 03-12-2018, 10:12 PM by Hedd_Jones.)
Jon
i assume staffs must have it in modern times?.
From August 1960 onwards 'BF' was a Lindsay (lincs) index, but always with a preceeding letter in a 3 letter index. Starting CBF etc
Car type:
hmmm... well the wangdang book I've bought is a bit inconclusive, and I think I read the story in one which is winging its way to someone now!! Lindsey was BE though, surely?
The numbers of BF until they changed was really low - only up to 162, perhaps in 1905...
And yes, it appears that after RF was used, from 1960 to 1963 (most of) the three letter *BFs were used.
So presumably that means that 9000 odd re-registered age-related BF have been made. Anyone have a low digit one?
I didn't realise their were parallel series for m/bikes and cars. Does that mean they used the same digits?
