Further to the Wakefield charts, they came in envelopes as stated earlier. In 33 the envelope had a red motif printed which was changed in 34 to a large red band and the same script. 36 envelope same but yellow band, and in 38 grey band.
If your still awake I have another 36 Austin Seven oiling chart with envelope, this time by Price's MOTORINE and it states "austin motor co recommend Motorine" . Interestingly Prices state gearbox oil capacity at 1.5 pints!
Russell, would love to see some pics.
Tony.
Tony pictures coming I wish I was more competent , have done the motorine. Seems I also have the Austin7 pamphlet for pratts and the original copy for castrol "austin 7 lubrication simply explained".
I will photo and post. regards Russell
17-11-2018, 09:59 PM
(This post was last modified: 17-11-2018, 10:05 PM by Dave Mann.)
Must be a senior moment not spotting the rear fuel tank and yes having blown up the picture I can see the centre longitudinal hiding behind the OS member. Having just done a propshaft job on an RN which ever side you approach it you have the battery box on the NS and the centre longitudinal on the OS much closer than in the picture.
However I suspect the artist has merely updated the original SWB drawing adding the centre longitudinal, 4 speed box, rear tank and 26Va carb, but left the SWB body mount on the NS end of the rear crossmember.
