Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
04-11-2018, 11:13 PM
(This post was last modified: 04-11-2018, 11:16 PM by Derek Sheldon.)
[img]blob:http://www.austinsevenfriends.co.uk/33d9274a-4c1b-4ff6-b5ba-e437959e2d22[/img]
Sorry didn’t make a good job of yhst
Car type: 1928 Mulliner Fabric Saloon
Tony the img brackets are correct the / is to signify a close (to make it easier to see beginnings and ends if you have a lot of code).
Derek the issue is that the link is to a page rather than a file. Usually if you right click an image (assuming PC) and open in a new tab the address at the top will be of a file, and will end with .jpg or some similar file extension. Unfortunately trying to follow the link to fix it I get a file not found error?
If you let me know where to find it, I can try to get the image up for you if you want.
05-11-2018, 03:38 PM
(This post was last modified: 05-11-2018, 03:39 PM by Derek Sheldon.)
Got it this time, sorry it’s on it’s side
[attachment=4374]
Well spotted Martin, now easier to read the registration
Car type: 1934 Austin 7 AVH Van (in bits & incomplete!), 1936 Morris 8 Series I Tourer
05-11-2018, 08:01 PM
(This post was last modified: 05-11-2018, 08:10 PM by Jeff Taylor.)
XVV 315 isn't on the A7CA Chassis Register but is taxed until August 2019. I think XVV is an age related plate dating from August 1979 when the car was 'first registered' according to the DVLA database.
Nothing wrong with that Mr Fawlty. Lick o' paint, one hour...
