03-11-2018, 12:24 PM
(This post was last modified: 03-11-2018, 12:25 PM by Chris KC.)
Tiger, Martin was right - stop and think what you have done since the crank last turned freely (and share with us please! otherwise we are all taking wild guesses...)
It also helps to know what engine you are talking about - for example 2 bearing or 3?
What 'work' did you do on the camshaft and bearings?
Have you had any of the big end caps off and if so check you have got them back on the corresponding rods and the way round they came off.
John Mason.
Car type: Ruby mk 2
To the best of my memory.
Only fitted the two front gears.
Also camshaft plus bearings.
If the nose cone is still off I'd remove the crank pinion and try turning things. This will tell you if it's the camshaft or the crank that's locked up.
Car type: Ruby mk 2
By the way 3 crank bearing engine.
Have you overtighetend the nut holding the camshaft gear on it's taper?
You really need to remove the camshhaft to do this job properly, if the gear pulls up onto the bush it will jam everything solid...
Car type: Ruby mk 2
After struggling all afternoon
Timing gear off.
It was in fact THE CENTER SUMP BOLT.
WELL DONE BILL G
Can’t thank everyone enough especially Bill
Regards
Tim
