I need to replace the radius arm brass bushes that fit over the ball on the chassis of my Ruby mk2 and was wondering if there was an easy way of doing this or is it definitely a full radius arm / axle removal job ?
Joe.
I think you might find there's enough twang in the radius arms to slip new bushes in place once the bolt is withdrawn Joe.
I use a pry bar to assist with this job.
