(14-10-2018, 04:12 PM)Management Wrote: Encountering the same problem using the "Log in" button below header on a page with scroll bar. Box jumps to bottom left corner and scrollbar disappears, so no scrolling further down possble.
Will work the problem and get back.
Did some change in the php code, now login box should show up in the middle of the screen.
If not, use your F5 button to reload the page (and update the used style sheet in the background), that should do it.
10-03-2021, 09:51 AM (This post was last modified: 10-03-2021, 09:59 AM by Chris KC.)
It's back. And I'm unable to log in from my computer.
"Authorisation code mismatch. Are you accessing this function correctly? Please go back and try again"
Ah, perhaps it's joined the list of sites which no longer work on IE. Managed to log in via Chrome. Still got the 'MyBB' thing though.
Log in? I never log in, it just works, and I never log out, so maybe that is a solution if the problem persists. The forum is open 24/7 on my PC, though I still don't need to manually log in even when the computer occasionally crashes and I have to re boot.
