phoenix cranks
I am looking for an 1 1/8 phoenix crank for building a spare engine for my 27 chummy.
Although not known for my patience, I will wait in the queue, but if anyone has one they would consider selling, please give me a shout.
Apparently an 1 5/16 will also fit, but I'm guessing that this would involve quite a lot of mods?
I am not going racing- mainly to the off- licence and back.
Have you tried David Cochrane (A7 components)?
Peter
(14-10-2018, 07:29 PM)Steve Clare Wrote: I am looking for an 1 1/8 phoenix crank for building a spare engine for my 27 chummy.
Steve, hardly any modifications to fit the 1  5/16 crank and a much better prospect .
You would need later main bearing housing, and flywheel, both easily obtained and not
expensive.Front mains are same .
You will require 4 x 1 5/16” rods, large rear main bearing housing and 30-32 type flywheel.
The flywheels are increasingly rare as many have been snapped up by those using 1 5/16” Pheonix shafts in their pre ‘30 cars. I have successfully machined later flywheels to suit however.
Many of the 1 5/16” rods available are cracked nowadays (for the same reasons as the lack of suitable good flywheels) - check carefully before fitting.
The 1 1/8” cranks supplies by David do mean you can use your existing parts, which is a good thing in my book.
