Car type: '27 Chummy, '34 Special, '50 Traction Avant
03-10-2018, 09:08 AM
(This post was last modified: 03-10-2018, 09:09 AM by Mark McKibbin.)
I have at last finished the special and on the first drive noticed the speedo reading about a third what it should do (odometer as well). I'm pretty sure if it was a magnetic type speedo it could be adjusted to suit but not sure about the "PA" mechanical type. Not fussed about the odometer. I know there are ratio adaptors available that attach to the cable but is there another way?
Mark
See recent thread 'Speedo Gearing' Mark.
Boils down to an adaptor box or recalibrate speedo I think.
Or fit teeny wheels....
Car type: RP Deluxe Saloon 1933
04-10-2018, 08:29 AM
(This post was last modified: 04-10-2018, 08:30 AM by Roger.)
Mark,
When my speedometer was not working I found the gearbox was assembled with no worm drive fitted.
This would obviously have caused problems as it acts as a spacer on the gearbox shaft.
On investigation I found there there were variations on how many starts there were on the worm and also how many teeth on the pinion. I had an 8 & 9 tooth pinion available so fitted the 9 tooth pinion and single start worm.
They appeared compatible but The Speedo shows about 30mph, the satnav reads 40mph.
There is an article in the BA7C somewhere I believe about speedometer drive gearing.
Roger
04-10-2018, 03:50 PM
(This post was last modified: 04-10-2018, 04:07 PM by Martin Prior.)
My RP has got faster and faster over the last couple of years and now regularly clocks 75mph!
Meanwhile, the 5-mile run into Hereford has stretched to around 300,000.
...........and as I'm now getting around 15 million mpg, why should I complain? Maybe that explain why the fuel gauge never moves.
Thanks for the replies, I think I will make a ratio correction box that will, as the speedo goes to 100 mph, make it read kph as I live in the metric country (Australia)
Mark
