Does that ring serve any important purpose? I couldn't get it into the housing, it was too tight. The original distributor didn't have one, so I've left it off. the car seems to run OK.
Alan
I guess its there to make a seal between the shaft and the housing, to prevent grease from the gears leaking out. It will go in with a bit of brute force but as you say it shouldn't make much difference - I've never suffered a leak like that and as we all know, Sevens will usually expel lubricants at any opportunity!
Alastair
15-09-2017, 05:22 PM
(This post was last modified: 15-09-2017, 06:40 PM by Derek Sheldon.)
I've been told to remove it, not required on an Austin 7
Thankyou both. I'll leave well alone.
Alan
Yes - it fits straight on top in place of the original base plate.
The only other thing to do is put the magnet ring over the points cam.
I agree - however, you get a brand new drive gear, bob weights, cap, acorns and rotor arm (plus body and spindle) for not a lot more - you do the math...
And for lazy old sods like me a brand new one will (hopefully) make constantly yanking the advance/retard lever back and forth on my tired dj4 a thing of the past. Set it and forget it?
Peter.
Cornwall, where the Druids are happy prancing round stone circles as that red ball in the sky has returned at last.
