When did Austin stop using "armoured" cable ?
And when they were using it how were the cut off ends sealed...or not? They can be pretty sharp. There are very smart & sophisticated ways of doing it these days, but perhaps not appropriate! I used some discreet heat shrink when doing some on my car.
I use Hellermann sleeves.
I'm pretty sure Austin stopped using armoured cable in late 1931, but I'll stand corrected on that if anyone knows better.
From memory, all the cars I have encountered with original wiring had the alloy armoured winding cut short revealing about ¼" of the black outer insulation.
Car type: 1932 RN saloon
I seem to remember that Wheatley and Morgan's vintage car restoration book said the method used was cotton thread wrapped round the ali cover and then varnished. Sounds a proper faff. I'm probably entirely wrong because it's about half a century since I read it.
15-09-2017, 05:38 PM
(This post was last modified: 15-09-2017, 05:41 PM by NickB.)
Mike my early 65 is mid 33, it had armoured cabling fitted when I bought it, no doubt original, and shortly will have new armoured cabling fitted once again. I think it changed in 33/34.
I wonder if it changed when looms began to appear?
That sounds typical Wheatley & Morgan! I am always amused by some of their comparisons between the right & wrong ways of doing things eg "Make a gunmetal casting". - I wish!
