Fan pulley assembly.
#21
In those circs Mark I would try to lose a few mm off the fan or pulley assembly (pref not an original sports one) somewhere - as you suggest, if you can recess the fan bolts it may do the trick. I'd suggest 1/8" clearance as a target.
(21-08-2018, 02:50 PM)Mark Dymond Wrote: how confident are you that the thread is imperial (3/16 BSF I presume)
Hi Mark,
I understand the correct threads are 3/16 BSF (ignore my reference to Whitworth earlier on, that is not correct) and that 2BA differs by about half a thread per inch, which is why it will fit.
I will leave it to those who can work these things out properly to confirm or correct that for me please.
Hi Mark,
Yep, 3/16 BSF. 2BA is very near enough!
With respect to red fans. Dad had a number of the Remax spares chests through his hands. And I still have one. The fans in them were always painted red.
(21-08-2018, 09:24 PM)Hedd Jones Wrote: With respect to red fans. Dad had a number of the Remax spares chests through his hands. And I still have one. The fans in them were always painted red.
Hedd - surely not relevant?  In all my postings, unless I specify otherwise, I've  only ever referred to genuine Austin bits.  Cheers,  Bill in Oz
Its perfectly relevant Bill. It explains why there are a lot of Austin 7's with red fans.
Hedd - I'm aware there are plenty with Red fans, as said I think you'll find Austin started with the 4-bladers, but what Remax or any particular owner has done doesn't prove what all fans were.  I was talking of original installations, sorry.   Cheers,  Bill
I paint the tips of my red fan blades yellow so I can see them flying past my fingers while I do silly adjustments with the engine running...
(24-08-2018, 05:25 PM)Duncan Grimmond Wrote: I paint the tips of my red fan blades yellow so I can see them flying past my fingers while I do silly adjustments with the engine running...
Ha ha, I thought that's why people painted them red Duncan!
I recall a tale of a Lady and her dog visiting Longbridge and the dog had it's tackle painted red.
