Modern fuel certainly seems to be causing problems in the wider classic car world, especially with rubber components in the fuel system - as others have said, flexible fuel lines, pump diaphragms and filler seals all seem to be affected. I have encountered collapsing hoses and disintegrating pump components, and know several other owners who have experienced similar problems. I am not a chemist, so have no way of knowing whether ethanol is the problem, or some other constituent of modern petrol.
Another problem I have encountered is stale fuel in a car which had been unused for eighteen months: the engine started and idled with no problem, but under load it misfired and progressively lost power. The solution proved to be a set of new plugs; apparently under rich mixture starting conditions the stale fuel leaves a varnish on the plugs which breaks down the insulation and cannot be removed.
I generally run my RP on supermarket brand 95 unleaded, but that's getting rarer as days go by and I may have to opt for 98 rather than the E10 based fuels. The RP seems to run on virtually anything and I've never experienced problems with stale fuel (to date). I am more worried about touring these days in the MGF, which is not ethanol compatible. It was new in 1997 and petrol cars before 2001 are not compliant. I don't think the occasional tankful will be over-detrimental but long term use can apparently cause damage to the fuel system, pump, seals injectors and various other bits. Be aware if touring that non ethanol based petrol is no longer available on the French motorway network so to get normal 95 or 98 unleaded you have to search elsewhere. (Most supermarkets have fuel)
I have heard however that even 'normal' 95 or 98 octane unleaded can contain up to 5% ethanol so there's not really much you can do other than keep your fingers crossed.
Car type: 1932 RN saloon
I noticed the Slosh fuel tank sealant in 2 x A7 tanks has areas of blisters. The Slosh was applied in 1992 for one tank and 2002 for the other.
I have usually filled up from one of the supermarkets with 95 petrol. To date I have had no problems and the RP starts on the first swing after 5 months layup. Never sure how much petrol is in the tank.
My Liege is Reliant powered and it may be of interest to note that the Haynes manual for the Reliant published in 1989 under routine maintenance states:-
‘Every 36000 miles (60000 km) or 3 years, whichever comes first’ - ‘Renew fuel pipes’.
The fuel pipes are a combination of plastic and rubber.
Ethanol perhaps contributes to the deterioration of these components but it appears not to be a new problem.
Roger
