Good afternoon. I am currently preparing the wiring for our AE based van. Could anyone advise me of the route that is taken by the horn cable from the steering box to the horn?
Stuart
Not sure of the route.
Just in case you haven't seen this, some wiring diagrams for 1928/9 are wrong and show the horn button before the horn. In fact it should be after the horn and there is a single wire which up the column which is grounded by the button.
Chris, many thanks for the promptness and detail of your response - exactly what I was hoping for.
Austin, you are quite correct, I have had a number of discussions with A7 owners who have insisted that 'because it's in the wiring diagram it must be right' with the misconception that the horn button provides a live feed to the horn rather than dropping it to earth.
Stuart
