Returning from a classic car show tonight, I started to move uphill from some traffic lights and there was a terrific bang and then the car would only move very slowly. I suspected a broken half shaft or a prop shaft coupling but managed to get a tow home? I jacked the back axle up and both wheels turn freely but when I turn them the prop shaft doesn't turn also if I turn the front prop shaft behind the gearbox the wheels don't turn. Too lat to carry on tonight but any ideas?
.....vbfhfgj
Broken half shaft woodruff key?
Andy
WE are all dead curious.
A failed key might explain the slight drive. Could be the pinion flange key? I have seen axles with the keyway broken out on both sides. The key must have been hard. Perhaps soft keys are being used (With a good fit should not matter)
After all the recent discussion I imagined everyone would be operating without the split pin and attempting to tighten their axle nut after every run!
A broken fan can totally unbalance the whole engine - this has only happened to me once but it was, as you describe, horrific!
Easy sort though.
At least it didn't go through the radiator.
When I first bought my Austin seven I spent half an afternoon tinkering with the timing to stop the pinking, only to be told that the starting handle 'handle' quietly jingles to itself when rolling along.
Might prove a useful thread 'Unlikely causes of problems: you'd never believe it!'
Andy B
I had a steel fan blade break in a Hillman. Made a large dent in a very heavy chassis meber. The vibration was incredible even at idle so had to remove the whole fan. it is surprising considering thr degree of (secondary) unbalance in fours anyway.
The possibolity is always worth bearing in mind when standing over an engine and revving it.
