Car type: RP Deluxe Saloon 1933
Finding my speedometer not working I used a drill in reverse and proved the speedometer and cable from the gearbox was all working.
The gear fitted has 8 teeth, on a spare gearbox I found one with 9 teeth, neither appeared to turn when rotating the drive shaft by hand.
The worm wheel on the gearbox output was not visible, the one on the spare box was far more visible.
Does anyone know how many teeth there should be, it is a 4 speed synchro box in a 1933 RP.
Roger
Dave,
It looks as though I have two 4 speed and two 3 speed, how do I tell them apart, they don’t all have tops, although I do have loose tops
![Huh Huh](https://www.austinsevenfriends.co.uk/forum/images/smilies/huh.png)
The spare 4 speed box has what looks like a single start drive gear, there was not one in the original one fitted to the car!
I take it that the 3 speed ones would not be compatible with my box.
Roger
Dave,
Thanks for your reply, a tremendous amount of information on the Speedex site.
I have now sorted the spare 4 speed synchro box, the worm drive is fitted but it is only a single start thread. The 8 tooth pinion meshes well with the worm, the 9 tooth pinion does not mesh so well.
I notice in the Speedex formulas the numbers are divided by either 8 or 9 so that Is obviously the pinion teeth value. I will use the 8 tooth pinion as a starting point.
My reasons for swapping boxes was first gear jumping out also difficult to engage, the spare box felt better when selecting gears on the bench, it also had the worm wheel fitted to start with, it just needed a good clean but was in good condition.
I was wrong, all the boxes I have are 4 speed, one has an”S” as you suggested.The other does not.
Thank you again for your help
Roger
