Yes Smiley that is ok. To high could be due to a blocked jet. I run on a 20/50 oil have done so since 1971. Change oil every 1000 miles.
09-07-2018, 08:59 PM
(This post was last modified: 09-07-2018, 10:16 PM by Hedd Jones.)
Ive done about 300mile since Friday in daughters RP.
Once hot got 0 on tickover. About 3 at 30. 5 at 50. 7 at 55.
It has a mixture of 20/50 and 15/40 in it cos I ran out of 20/50
Reckless...55mph in an RP.
tell me it was downhill...
Andy B
09-07-2018, 10:13 PM
(This post was last modified: 09-07-2018, 10:15 PM by Hedd Jones.)
55 was downhill. But it sat for mile after mile at 50.
It has always liked humid weather.
My 55 was on the flat. I've also got it on vidéo. 37 head + H1 SU.
Very impressed, and slightly scared
My current RP top speed is around 45 but I know my top end is tired.
Andy B
My 1929 RK oil pressure is approximately 1/10th of speed in mph.
I think the specification is between 2 & 4 psi at 30 mph with the engine hot.
I have fitted a Bullnose Morris pressure gauge which is calibrated up to 10psi. When the engine is cold the needle goes right round and hits the stop at zero coming from the other direction. My guess is well over 30psi.
That's OK because the gauge says "Guaranteed to withstand an overload of 200lbs".
The car cruises happily at 50mph. Easily reaches 55 with 60+ downhill.
