Tourists generally kept going with the assistance of momentum. Marshalling at T C 7 we had to assist a couple of Rallyists to get away up a hill that certainly was not marked with chevrons. Some folk get
a bit upset at the number of sevens active in LCES and other events, but there can be no more positive indication that Sir Herbert got it very right with his baby. As for the pictures, one might wonder whether you had strayed from the road book and gone down to Reg Mays, the butcher in Ditton Priors, for some Biltong.
I don't use anything but "super" grade in the old cars (and lawn mowers) since having similar problems like this, and it going "stale" fairly quickly.
Not had a problem since.
25-06-2018, 07:33 PM
(This post was last modified: 25-06-2018, 08:13 PM by Steve Jones.)
We were a couple of cars behind you when you expired at one point, Robin. A shouted 'OK'? resulted in 'Petrol Vaporisation' so we carried on. Looking at the photo I'd suggest the opinion that old 'slosh' sealant might be the answer but for that to be right, the tank's had to sealed with it at some point in the past.
Mrs J doesn't find petrol works well as nail varnish remover but in absolute desperation, cellulose thinners does. Best not ask how I know this!
25-06-2018, 08:07 PM
(This post was last modified: 25-06-2018, 09:06 PM by Robert Foreman.)
As Russell suggests I would say that it is some form of sealant that has started to disintegrate When we repaired Russell's tank I removed a dustpan full of the stuff. Try looking inside the tank with a long dentist mirror and bright torch.
Glad the petrol tank repair is holding up Russell
