Yesterday, 06:23 PM
Bulb type…
Yesterday, 07:23 PM
I think that's 15D, the 15 being the diameter in mm. But please wait for others
Yesterday, 07:23 PM
Hi
I think that's a BA15d base. The staggered ones are BAY15d https://www.classicbulbs.co.uk/products/...bulb-b383b Please double check, it's a bit of a minefield !
Yesterday, 07:29 PM
I was just about to add that having done a bit of searching and agree BA are parallel pins and BAY offset
Yesterday, 07:45 PM
Thank you, John and Andy - very helpful indeed.
Ruairidh
Yesterday, 07:56 PM
I suspect its 25/25 Watt headlight bulb. As mentioned already its 15d bayonet fitting.
Yesterday, 08:00 PM
(This post was last modified: Yesterday, 11:13 PM by Tony Griffiths.)
It's a slightly unusual bulb in that the pins are parallel. Most stop/tail bulbs have offset pins, so the bulb will fit in one direction, allowing the correct tail-light and stop-light contacts to be made. The earth return is through the body of the bulb.
Some single-filament bulbs have a double base contact, one for the live feed, the other for the earth. One of the problems in ordering bulbs is that the sellers often miss out important information or put up useless pictures. e.g this retailer, while this one has all the data correct
Yesterday, 08:17 PM
I had a similar problem when I replaced my rear lamps for the pattern L582 type lamps. The lampholders were for for parallel pin type bulbs and all I had in stock were offset pin bulbs. Got over the problem by filing the upper pin off.
2 hours ago
Hi Rory, yesterday I was also trying to find some 5/21 W bulbs with parrallel pins, can't find any suppliers so if you do could you let me know, I'll do likewise if I find any!
1 hour ago
See John Cornforth's reply, above, Gerry.
Users browsing this thread: Tony Griffiths, 1 Invisible User(s), 1 Guest(s)
