  • 1 Vote(s) - 4 Average
Sump bolt thread restoration
Hi all,
I'm wondering if it's possible to restore the 1/4" threads in the crankcase back from the 5/16" threads that it is currently? I'm thinking of fitting an ally sump, and it will be a shame to drill it out to 5/16.
Or would it be better to change the crankcase?
Ta.
Cheers, Geoffrey
Fit helicoils.
Do helicoils work for threads already tapped out to 5/16"? I've never used helicoils before.
For example, would these work?
https://nzsafetyblackwoods.co.nz/product...-20-457154
Cheers, Geoffrey
No they don't, if the case is already out to 5/16 or above I use bespoke brass or aluminium inserts to plug the holes if the case
Ah, okay. I'll look at getting some plugs made up, I guess. It could be an engine-out job.
Cheers, Geoffrey
How about converting to stepped studs, 5/16" down to 1/4"? That would save an engine out job.
(11-05-2025, 07:34 AM)bystander Wrote: How about converting to stepped studs, 5/16" down to 1/4"? That would save an engine out job.
Good point! I never thought of that. Thanks.
Cheers, Geoffrey
Studs will work although they can make sump removal in-situ difficult. I would not recommend undertaking any of this work without removing the engine first.
(11-05-2025, 11:52 PM)Ian Williams Wrote: Studs will work although they can make sump removal in-situ difficult. I would not recommend undertaking any of this work without removing the engine first.
Hmmm... it does make sense. I'm inclined to plug the holes with brass inserts and start again, then use cap screws and fibre washers.
Cheers, Geoffrey
I make a steel threaded insert from 3/8"BSF studding with a blind hole. I set it in the crankcase at the set height with Loctite. No more stripped threads.
