Isn't the Eltos shown for a three speed gearbox- the later discussions are about a four speed remote which is different.
Just curious why is there a big notch in the Eltos at the start of the tube ?
09-04-2025, 01:04 AM
(This post was last modified: 10-04-2025, 12:17 AM by Tony Press.)
Of course !
Never seen a four speed Eltos - must have had a clever reverse lift
Cheers.
I have used a 4 speed Eltos very succesfully for well over 30 years, mine uses a reverse lockout based on the ones Austin fitted to their single seat racers. I have also used several homemade variarions on the remote scheme all of which rattled but otherwise worked well enough. One of the nicest 4 speed remotes I have seeen was made by my late friend Joss Campbell, I posted pictures of it on here a few years ago.
Car type: A7 special 34
I have driven a few sporty modern cars with paddle gear change on the steering wheel but this is a close as you can get on an Austin 7. Very clever use of steering parts to make a gear change!
