Thank you Ruairidh, for your tip. I tried this and then tookthe car up Bwlch-yr-Eira on the B4391. The car climbed the steep bit in third all the way. Previously it required second for part of the climb. It then managed the rest of the pass in top at between 25 and 35 (depending on gradient) all the way to the crest, whereas, before parts of it required third. The little car seems to be going better than it has ever gone and so far no more clutch slip.
Great news - happy days ahead.
Hi Folks,
Today I stripped down a fuel pump cleaned it all out fitted a new diaphragm after spending a while getting rid of the wear marks on the lever arm with an oilstone.
The body is marked 7 hp T Type pump.
This pump is destined to go onto a Nippy Engine which is partially assembled.
If he gives up Sevens, I reckon Mr Dunford could have a career as a romantic novelist or a script writer. What a lovely story.
Congratulations, Charles. A significant achievement! I take my hat off to you.
All the best,
Stuart
Yesterday being Passion Sunday, I indulged in my passion and drove the Seven, Not far - just up to Llyen Celyn to see how the major dam reconstruction works were going and a separate trip over to visit friends at Llandderfel. about 20 miles covered in all.
