Keeping it original.
Can anyone help me keep the original look of my 1930 Swallow?  Under the bonnet may not be immaculate but it is surprisingly original.  To keep it that way I need to find some brown plastic covered HT cable. At the very least I  need enough to replace the king lead but can't seem to find it anywhere.  I have the original brown dist. cap but it looks wrong with a black king lead.  The car is still 6 volts.
On another point of originality, I would like to find an original condenser; the type  that fitted in the recess under the distributor.  Even if it doesn't work, I would like to have one fitted in the original location.
Any helpful suggestions would be welcome.
Thank you.
I thought that a 1930 Swallow might have had a Lucas DJ 4 manual advance with a black cap, mushroom cable ends  and inside condenser (or would it be a DK4 Auto Advance - again with black cap with acorn cable ends and inside condenser).
I have some of the CAV condensers, Ray.
Ping me a message.
I don’t know of any Brown HT lead, Ray, but as second best could you use brown heat shrink tubing to cover a lead of a different colour?
Regards,
Stuart
Hi Ray
Rinsey Mills book doesn’t show a picture of the engine bay of a Swallow but does show a remarkably original 1930 AE.  I can’t imagine Swallow changing the engine from a standard Austin one? The HT leads are fabric rather than hard plastic and ‘look’ brownish.  However they were probably black originally and have faded.  The dizzy in the photo is a DS with push fit HT leads.
The big external condenser can be hollowed out and a more modern one fitted inside.
Anorak Howard  Big Grin
Thank you everyone. When I say "original" of course, what I really mean is how it has looked to me for the past 40 years. The distributor is a CAV DS4 - 2 . It should have an external condenser, a brown cap and rotor arm and brown push in leads. It only looks right if everything matches. Yes, of course I could change everything but what's the point?
Ray.
