Oilite comes ready loaded with oil, they say. I always soak them an hour or two in hot oil. The stuff that goes in engines. I use lip seals not felt on the hubs, but if I did use felt it would be with a smear of grease.
24-02-2025, 08:24 PM
(This post was last modified: 24-02-2025, 08:26 PM by Reckless Rat.)
The accepted period lubricant for felt seals was tallow, a form of beef dripping made from rendered suet. I have done mine in duck fat, which does the job. Just heat it up until it melts and leave it in the dish overnight. I guess common or garden grease will do fine, some of that stuff you have a 3lb tub of, but wipe off the excess.
The secret for your hubs is not to over-lubricate. Too much and it'll go where you don't want it.
I just use the duck fat because we often have "confit de canard" for tea, and I always ask the Mem'Sahib to save the fat. It's great for roast tatties too.
Car type: Austin 7 RN - 1932
Well changed my mind and ground a little off the outer edge of the lip seals and managed to press them in. I found that the outer-part of a 1970's Maxi front wheel bearing is just the right size for pressing in the vice. So the felt will go in the spares box.
QUESTION -
The Girling brake levers have a small felt seal/washer between the lever and the oilite bush - does this mean it should be oiled?
