Core plug seat corrosion
Does anyone know the best way to seal a core plug which has a corroded seat?
Being a time served bodger, I would clean out the remnants of the old core plug, clean up the top surface of the casting and araldite a metal disc to the cleaned up face. The cooling system isn't pressurised so it should be fine thereafter.
This is assuming that it's a "cooking" engine and not something likely to be presented to the National Association of Rivet Counters.
Yours sincerely
Scrooge Mc Duck.
If you can install a new plug without it disappearing down the hole I imagine it would seal adequately on its OD.
Failing that I'd be inclined to thread a new plug into the hole, possibly dispensing with the horizontal flange; though I have not heard of this being done I can't see why it wouldn't work.
+1 for tapping and threaded plug. Unfortunately I think the core plug hole is slightly bigger than the hole at the top of the king pin otherwise you could have used a brass king pin plug.
It looks as though this is not an A7 core plug problem. The threaded plug idea seems sensible. Flanged brass BSP threaded plugs may be available in a suitable size, and if so a tap will also be easy to get. Try heating and plumbing merchants.
On the bench, put 2 welch plugs back to back. Drill a hole through the centre of both. Drill one out to a clearance fit for a small bolt, and tap a thread in the other hole of the other plug.
Put the assembled 2 plugs into the hole in the engine and gently tighten the small bolt. As they flatten, the 2 plugs should work as intended.
I had a similar problem and I tapped the hole I think 1/2" BSP and fitted a screwed plug fitted with a zinc sacrificial anode.
Many thanks for all the advice.
I have fitted two new core plugs so far. I despatched my father to pick some up from Jamie at the seven workshop. The new plugs seem to fit, but for whatever reason I cannot get them to fully seal.
I favour employing bodgit and scarper ltd, along with a new tube of araldite as the next attempt.
If that doesn’t work it should relatively easy to grind it all off and then try the threaded hole / bolt approach.
My initial plan was to replace all three core plugs on top of the head, but given my lack of prowess at fitting the things I might leave well alone!
Since the engine is more of an air fryer than cooker ( I get lots of insect splats on the rear screen and none on the front) I don’t expect any issues.
Apart from the lack of steering out of roundabouts, the Austin is really running well at the moment, so I’m loathe to fiddle too much.
Thanks for all the advice.
Sound looking repair by Bodgit and Scarper. Not leaking yet!
Araldite Steel rapid.
On to the next problem.
(Yesterday, 12:41 PM)Lowbarn Wrote: Thanks for all the advice.
Call that a bodge?
We dreamt of being sophisticated enough to use Araldite.
I'll raise you with a more bodgy bodge -albeit Fiat, not Austin
