Cleaning Block Waterways
I am having to get a block re-bored following the seizure of the engine in our Pearl on the way to David Nightingale. I thought I would take the opportunity to de-rust the water jacket. I am considering using  Bilt Hamber - Deox-C. Does anyone have any experience or alternative suggestions?
Martin
My solution is a sodium hydride bath. Not a domestic process but very, very good.
These people do it
https://lentontreatments.co.uk/
I have used the Deox-c. It works well removing all corrosion.  The solution can be used again and again untill it no longer works - check with a small rusty off cut.  I think that using a strong solution rather than a weaker one would be best.  It took several days to get my bits cleaned up enough and as suggested fairly frequent agitating helps as well as scrubbing the surface with a wire or other brush to remove the black deposite from the chemical action to reveal shiny clean surface.  You can make up enough solution in a large enough plastic bowl to put the whole block in fully immersed which would do the outside as well. Once satisfactorily cleaned the piece can be just washed off with clean water. The bottle of powder goes a long way, making up lots of solution.
Several members of my Reliant Scimitar club have also cleaned out their V6 3litre engines and radiators using neat Coca-Cola, but of course it is not re-usable afterwards  Wink.
During use the solution gets progressively blacker.  With more gentle use on something not too badly corroded the remaining solution can be drained through a filter (coffee filter) into a container for storage till next needed.
 Th
Dennis
Be aware that Deox C does remove a small amount of parent metal and I make sure all threaded holes have greased studs fitted and I do it with the old valve guides in and yes it does a good job. The last one I did with the head on and and pumped circulation
Lenton Treatments are a +1 from me. Excellent company. Used by many vehicle restorers including one of our own.
Users browsing this thread: Dennis Nicholas, Hugh Barnes, stuartu, 5 Guest(s)
